Everything posted by nbdxbigshow
Random No Start Just Clicks
nbdxbigshow replied to nbdxbigshow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk that seems about right for the milage I think my gas gauge is not reading correctly , I just get a smell of raw fuel sometime when I start it and it goes away but I feel like the car is kind of sluggish lately I just recieved in the beck arnley knock sensor I will put that in over the weekend see if that helps anything , as for the work around on the solenoid the #Part No: 24106-BX I ran a wire directly from the battery to the right side of the solenoid and the single wire going to the starter up to the new center post on the solenoid which I believe is the energizer wire then the left side of the solenoid goes back down to stater engenizer wire, seems ok I haven't had a problem with it for a few days now hope this fixes it for good, let me know if you think the catolica converters need to be changed cause of that P0420 code
nbdxbigshow replied to nbdxbigshow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a single click, only clicks once each time if I turn the key forward
nbdxbigshow replied to nbdxbigshow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon a tank of gas i probably get 250 miles I think that is not very good at all does that sound right to you ? I will put it up on the lift in the next few days and take some pictures where the oil leak is it looks to by what you are saying the rear separate plate that seems to be common problem I heard is there any way to fix that without all the work ? the car only has a 110,000 on it and is in very good shape with no rust so I would like to fix it and make it run right I also have replaced plugs, wires, air filter, new PVC valve no luck could it be a plugged converter I will going to replace those was not defiantly sure how to tell if there are really bad or not any way to check them ?
nbdxbigshow replied to nbdxbigshow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfternoon Guys was wondering if this looks right to you (mikec03) I hooked up a high voltage solenoid going to give it a try and see if I have the same issues usually happens once a week so I will keep posted as for the codes its throwing (idosubaru) I have attached pictures below any input would be great let me know if you thing its the Cadliac Converter and if you know of a reasonable place online to get them I am going to get the knock sensor that may explain why the car is sluggish a bit and poor gas mileage also I am dealing with the good old Subaru oil leak onto the exhaust looking to be coming from in between the transmission and the motor any idea on how to fix that would be great also, let me know you guys and again I appreciate the help
nbdxbigshow replied to nbdxbigshow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am going to put it on the lift this weekend and check the following you guys had pointed out and give those a try if you guys think anything else to look for Just let me know I appreciate all your guys help I will follow up after I also had another question even since I purchased this car it only had 84,000 it has always had a poor idle always at about 500 rpm just idling and will never idle where it is supposed too I have cleaned the erg several times and I have also noticed that when its damp or rains it idles rough and then clears up I have changed the wires and plugs with NGK replacement also replaced coil and swapt out the igniter I have another 95 Subaru identical to the one I have no and been using as a donor for parts the struts finally came through in the rear at 250,000, it ran better then the one I have now please let me know you thoughts on this also thank guys I appreciate all you help
Hello Guys , I am new to the Form I have been working on cars for a long time and I have finally found something that I am stumped on and cant figure it out I have a 1995 Subaru Legacy L AWD wagon Automatic only has 110,000 ,the issue I am having is randomly it is will give me a no crank it will just click I have replaced the starter tried 2 new ones New battery new alternator I have also tried starting it in neutral , with no luck for example this morning took my daughter to school started right up no issues can back home a hour later went to leave for work no start just clicks, it has progressively seems to be getting little more frequently if I keep trying and letting it click is will all of a sudden start cranking and the car will start like normal ,I was wondering if someone can help me with this and point me in the right direction or has a similar problem that they have solved
