htan22
  1. Also...You said you could get it into the gears when it was turned off...Did you just put it in first ..clutch it and start it?Then have it pop out? Or do you start in neutral? Thanks for the info! - no, it did not pop out - I started in neutral
  2. no - that wasn't me - would you happen to have the link to that specific thread? - thanks!
  3. There was no grinding and yes, the car would shift into gear when the engine was off.
  4. I was driving home from work yesterday and I came to a stop at a light and put the car in neutral. When I tried to shift into 1st - the shifter wouldn't move. I wasn't driving hard or doing anything crazy to the clutch - I was just going home driving "normally". I tried turning the car off and restarting a couple of time but the shifter still wouldn't budge. While I waited for a friend to come check out the car, I tried restarting several times but no luck. Finally, after about 45 min. my friend arrived and I restarted one more time and then magically, the shifter went into gear. I drove straight to the dealership. They said that they couldn't find anything wrong with the clutch/tranny/shifter. Basically, they told me that they had no clue what happened and that the car was safe to drive as far as they were concerned. Does anyone have any ideas about what happend?
  5. In what ways will the 2.5 be better than the 2.0?
  6. In what ways will the 2.5 be better than the 2.0?
  7. In what ways will the 2.5 be better than the 2.0?
  8. I am looking at buying a WRX Sport Wagon- should I start looking at 2005 models or should I wait for the 2006 models to come out later this year- does anyone have an inside scoop about any major changes for 06?
