xocomil21
Everything posted by xocomil21
  1. I just replaced the oil pressure sensor switch on the drivers side of my 2010 Forester. The videos I saw said to be very careful to only torque it to spec - 12 lbs/ft - as it's very easy to crack the cylinder head. The old switch came out easily, but the new one won't sit flush with the cylinder head before I hit 12 ft/lbs. I did try putting the old one back in and same thing with resistance coming in before it was sitting flush (ie. the threads not sticking out a little). I'll admit I increased the torque to about 13-14 ft/lbs due to using an extension, but left it at that, as I didn't want to hear a "CRACK."
  2. Thank you guys. I found an adapter at UHaul that'd do the trick! How hard is it to find the right wires to splice? I'm no electrician, but am reasonably mechanically inclined (from my days repairing almost everything on old VWs)
  3. I'd like to tow a small utility trailer with my 2000 Impreza. I have the hitch but need to install the basic 4-prong trailer wiring on the car. I read that some cars come with the wiring pre-installed from the factory ... so you just need a kit with the right connector to get the trailer wiring set up. Other cars require splicing, and hard wiring the extra cables, etc. Not sure if my Impreza RS would have been set up for towing from the factory ... took a quick look today but didn't find anything ... but it was -10C and really windy so I didn't look that hard. Thanks in advance!
  4. Thanks guys. Spark plugs ordered. Wires next on list (will try ocei77 trick to test them, if needed). PS - how many blade bits is the gap supposed to be? Haha
  5. Ah and here's one more photo .. rough gap measurement (didn't force anything in)
  6. I have a 2005 Legacy 2.5i non-turbo. Starting yesterday the engine started hesitating a tiny bit on acceleration while my wife had the car. That evening she noticed the engine light went on and the cruise control light started flashing. I went to a parts store today and they pulled a code - P0303. Misfire in cylinder 3. After hearing the cars issues, the parts person said most likely plugs, plug wires, or ignition coil issues. The code is off now, but the car continues to hesitate when under load - more noticeable when accelerating in 1st gear. Idle is fine. Starting seems ok too. I bought the car 6 months ago from a family member. It has 150,000 km. The head was redone (with new plugs) around 90,000 km - so 60,000 km ago. Not sure if plug wires were replaced but they look to be in ok condition. I removed the #3 plug today. I've attached a few photos if someone could give their opinion. I'm thinking to buy new NGK OEM platinum plugs at around $9.99 CDN each. If that doesn't solve the issue perhaps I should replace the plug wires? A diagnostic seems to cost a few hundred bucks, so I thought why not replace the plugs before going that route? Thanks for any / all advice!
