732002
Posts posted by 732002
I had the same problem with my 96 OBW (oil in the coolant)
I had every thing fixed while the engine was out.
Seals,valve guides,oil pump, water pump.
If you plan on keeping the car a long time fix it all, if not
now maybe a good time to dump it.
In 5+ years I will know if I did the wise thing.
My only complaint with my 96 OBW is doing the head
gaskets at 127K. I bought Subaru because it seemed
like it was a simpler car with less to go wrong.
Looked at a Audi 100 wagon. More money and did not drive
better then OBW.
If I got a VW it would be TDI for the mpg.
My auto 96 OBW gets 22-24mpg. Might be better with
new HG's.
I wish I bought a legacy L wgn. They sell for less, I don't
need the ground clearance, and I think the 2.2 has less
head gasket problems than 2.5's.
I go by the trip odometer not the gas gauge.
96 OBW 2.5 22-24mpg highway trips don't
seem to improve my mpg.
I should have bought a 2.2 legacy wagon. Better
MPG and head gaskets.
Yakima should have what you need. On my OBW their racks mount
to the stock subaru rack. Don't go too long on the bar or you will
hit your head on it.
Edit: I missed that you need the bars farther apart not wider. Sorry
I have no idea.
Oil on the ground and in my coolant. I had hoped that
Subaru would be more reliable and get better MPG. Is
great for getting to the mountain to snowboard and
plenty of room for the windsurfing gear.
Going to have a bunch done and hope to see 250K
Rebuilt heads,seals,T-belt,oil+water pump.
It could also be the valve guide seals. Were these replaced when
the head gaskets were done? When you down shift the engine
vacuum tries to pull oil past piston rings and valve guide seals.
Then when you get back on the throttle you see a puff of smoke.
Compression test would help to rule out rings.
Thanks for the picture. Mine looks worse. I will get it fixed
before summer.
Might also do the head gaskets since I don't know if they have
ever been done. Also there is a improved gasket. I plan on keeping
the car.
There goes my tax refund!
I took a look under the car. The front cover (not sure if that is what
it is called) looked damp on both sides. This could be from cam seals
and or crank seal.
Valve covers did not seem that bad. Could be oil blowing back from
from front cover?
I think the water pump is recomended because they will be there and
128K miles.
Thanks
I noticed a little oil on the driveway and asked the mechanic to
look. They say leaks from cam seals,oil pump O rings, and crankshaft
seal and that oil on the timing belt can cause the belt to
break. Is this true? They say it should be fixed in several months.
For $800 they will fix the seals,change timing belt,waterpump and valve
cover gaskets. for $1200-$1500 the Head gaskets could be done plus
all the other work.
I bought the car at 96K and now has 128K I don't know if the head
gaskets had been replaced before I bought.
What would you do?
Thanks
Update - Still looking for a Subie in PDX - thanks for the advice
Posted
I would look at a L wgn with the 2.2L engine because it
has less problems. Does your friend ski/snowboard? If not
AWD is not needed for Portland weather. Subaru is very
popular here so there should be many cars to pick from.
Also check for oil leaks, Cam/crank seals etc and get a PPI!
