Blooroo86xtGL
Everything posted by Blooroo86xtGL
  1. What LED? And it was fine before i changed it but i hear theres a certain position on the TPS?
  2. New fuel filter, before i changed the TPS sensor it was fine its just i had bad throttle response. Drove and idled fine just throttle response was terrible
  3. Hey all idk if anyone can help me i finally got my Xt running decently but my only issue was bad throttle response but did run good. It idled fine but with throttle response it was very terrible, I would have to floor it to send a signal through so i figured a bad TPS. Only thing is not i changed it with a new sensor and i musta thrown out either the alignment marks on it or there’s a throttle relearn procedure I don’t know about. All advice appreciated.
  4. How many are supposed to be on the negative vs positive?
  5. Hey all so i just finished rebuilding my EA82 and i have a no fuel issue. Starts with starting fluid but then dies when i stop. I have pressure from the pump and it has new fuel injector. It ran before just fine it started this issue after i put the engine in. Maybe im missing a wire? Or a fuse/relay went bad. Can anyone tell me where the box is for that? Or give me ideas
  6. Hey all, currently rebuilding my 86 XT and in need of help. Was wondering if anyone has the measurements for the freeze plugs that sit under the rocker arms. Tried the dealer and they dont have anything on it i was wondering if anyone knows what it is or if anyone has a specific part number on the freeze plug i can use that'll be awesome. All help suggested
  7. I’m currently rebuilding my XT and the previous owner said water pump was leaking but when i took off AC compressor i found out that the hose going INTO the water pump completely rotted away. Spoke to Subaru and they were able to give me part numbers but nobody has it, does anyone possible have a spare i can buy off them or i might have to find a fabricator to make me something like it. Found a website that has it but i never heard of it so I don’t want to resort to it unless i have to. Subaru part number is 14050AA001. All advice accepted
  8. Hey folks first post since im new but i recently bought an 86 Subaru Xt GL 5 Spd with 36,000 miles and i was wondering if there are any 5 lug spindles i can convert it with maybe a newer gen subaru so i can have better rim options
