Dan092181
  1. Thanks! If it's the seals, does that require pulling the timing chain off, or can that be done "easier"...? (I've seen the video's on how to replace water pumps on the 3.0...yikes...) Thanks in advance.
  2. Hello everyone, 2002 Subaru Outback 3.0L V6 LL Bean Wagon Recently, after I drive the car, it loses almost half a container of antifreeze. It doesn't really appear to happen when the car is running. For example, I started the car earlier, and let it idle for 20 minutes....no leaks while the car is on. However, once I turn the engine off, it stars coming out in droves..... I traced the leak to the little hole in the picture. It's on the bottom, drivers side, just after the gasket where the water pump is, etc Any idea's what's happening? The fluid appears clear/green, and doesn't appear to have any oil/gas in it..... Thanks in advance!
