Wilco88
  1. Wilco88 replied to Wilco88's topic in Subaru Retrofitting
    Yes thank you the car is due for an overhaul
  2. Yes this is what I'm guessing master or slave, might as well replace both
  3. Wilco88 replied to Wilco88's topic in Subaru Retrofitting
    Yes I'm learning towardss slave or master cylinder
  4. Wilco88 posted a topic in Subaru Retrofitting
    Hello there I know there's a bunch of clutch related posts but I feel mine is different. Okay my car is early 95 WRX ej20 with TD05H Pretty sure the gearbox and clutch is factory. Car was driving fine and everything but then I had to put the car into storage and was not driven for like 6 months. After 6 months I needed to move the car and noticed some issues with the clutch. It would stick to the floor and would come up if I pressed it a few times. It would be intermittent issue not every time but lots Clutch would press in and stay there but it would come up if I pushed on it a few times. I thought it would be the clutch but now I'm reading it could simply be air in the lines or bad master cylinder??? Would the fact the car was not used for months and stored affect the fluid in the clutch lines? Should I get a professional to bleed the clutch or what do you think I don't want to go out and buy new master or slave if it's not needed? Thank you sir.
  5. Hello there I know there's a bunch of clutch related posts but I feel mine is different. Okay my car is early 95 WRX ej20 with TD05H Pretty sure the gearbox and clutch is factory. Car was driving fine and everything but then I had to put the car into storage and was not driven for like 6 months. After 6 months I needed to move the car and noticed some issues with the clutch. It would stick to the floor and would come up if I pressed it a few times. It would be intermittent issue not every time but lots Clutch would press in and stay there but it would come up if I pushed on it a few times. I thought it would be the clutch but now I'm reading it could simply be air in the lines or bad master cylinder??? Would the fact the car was not used for months and stored affect the fluid in the clutch lines? Should I get a professional to bleed the clutch or what do you think I don't want to go out and buy new master or slave if it's not needed? Thank you sir.
