Sherman
  1. P.S thank you as I just ordered new KYB oem struts and have sourced both ways to go,Baja springs and or 50mm spacers again thank you for the help
  2. Sorry and yes my goal is a stiffer ride and 1" or more height gain,I know the strut itself does nothing for height or lift its the spring and or spring rate the "taller " means the complete strut ,(strut ,spring and tophat)side by side are almost 2 inches taller out of an 05 OB vs the ones in my 01 OB is why I was asking about them.. I know taller isn't always gonna raise the car due to spring rate as it can be 3 inches taller but if the spring is softer and gives more with weight you have gained nothing.. Nevertheless my 01 OB needs new struts and I was just curious if anyone had put 05 or newer sruts on an 01 but obviously not since I did not know the 05 and up are known to be weaker than those in the 01
  3. If i.knew for sure the 05 and up will work I would go with new since I have seen side by side pics and the 05 struts appear to be a couple inches taller but I have to order them and not work, I guess I will just go with new OEM struts with spacers but I appreciate it
  4. Its probably on here somewhere but I have a base 01 Outback and the rear struts are shot and a friend has an 05 with a blown engine and I need to know before pulling anything apart if the struts from his 05 will work on my 01,they look the same in the car, and I have pulled pics from the internet and they look the same side by side in pics.. The top hats are 2 studs the bottom is an eye bolt all look the same but the 05 looks a little taller, can anyone tell me if they will bolt in even if I have to change the top hats?
