Everything posted by B14CKL15T3D
Headlights are unable to switch off at night
B14CKL15T3D replied to B14CKL15T3D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk ill have to take a look, but yea the link that was sent I must've only clicked on the one that wasn't in english. I've looked it over a bit and I just don't see why it would have anything to do with the DRL, DRL should be a completely separate circuit from the headlights. I have no issues with my DRL just with my headlights unable to turn off at night even with the switch off.
B14CKL15T3D replied to B14CKL15T3D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso, I checked out the file you sent and its not in english so I cant really do much with that.
B14CKL15T3D replied to B14CKL15T3D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot the switch either since during the daytime I am able to turn the lights on and off freely without issue. I'm almost 100% sure all it is is the relay, I just need to know what kind of relay I need to get.
B14CKL15T3D replied to B14CKL15T3D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do know it's not the daytime running lights, I don't need to disable them. I just need to figure out if it is a relay, sensor, or some other electrical component. I've only started having this problem for about 3 or 4 months. Also, the lights don't turn on when I turn on the car during the day, they only turn on when it's dark out and will not turn off with the switch (like it's supposed to).
I have a 2005 JDM Subaru Legacy B4 that has automatic headlights (when the switch is on) and when its dark out the lights automatically come on. My problem is that when I need the headlights to be off, they wont turn off when it is dark outside (when the switch is off). I've done a little bit of research and found that it is most likely is a headlight relay. The problem I am having is that I have no idea where to get one or if that is actually the correct problem. I just came from Japan and even over there I wasn't able to find the solution (kinda difficult if you dont speak Japanese). Now that I am no longer in Japan and am shipping my car to Germany, I am afraid that my car will fail the inspection (inspections here are very intense). So I want to try to get the part in before my car gets here so that if it does fail I can quickly swap the part so it will pass (regardless, I want to fix it so before or after doesn't really matter). I also don't know if the USDM Legacy GT models have the same headlight setup or have the same electrical components. So I am at a loss and am looking for advice.
