Pilgrim 54
Posts posted by Pilgrim 54
USMBs a great sight! Thanks for all the imput one and all!!! Have a great Holiday!! I'm on the side....Pilgrim
The bolt is right handed but very tight. Some have used a breaker bar and rest it against the ground, then disable the ignition by removing the spark plug cables or pulling the fuel pump fuse, then hit the starter. The bolt breaks free. But I usually hold the flywheel with a large screwdriver and a long 1/2" breaker bar.
Regarding failed tensioners. Yes they do fail. I have seen bad bearings on them. Also failed tensioners. Both the original tensioner and the newer ( 97 to current ) tensioner/pulley assy. Seems the plunger becomes stationary and no longer extends. This causes the belt to flop and the pulley to bounce. It sounds like a bad rod bearing or piston slap. Easy to determine, just remove the drivers side timing belt cover and start the car. Look down and watch the tensioner. If it bounces or the belt, then the tensioner is defective.
Biggest cause I have found is a servicer, when replacing the timing belt, doesn't take their time compressing the tensioner. It calls for no more than 1000 ft/lbs and MUST be done vertically. Many may use a VISE to do this ( not correct ). A C-clamp serves better and it takes 8-10 Min's of small turns to do it correctly.
Subaru also had a TBS about these for the 99-02 models. And under warranty replaced many of them.
End of my $.02 and experiences ...........
Ferret You hit the nail on the head. Read my post about the tensionre. Great advice!! This thing could have caused a great deal of pain had one of the cam gears slipped timing!! Pilgrim
Nipper The reason I looked at the timing belt was it is supposed to be inspected at the 30K service. Then this fiasco started cause upon removing the inspection cover on the left side of the engine I found I could move the belt up and down about an inch!! Now that is simply not right.
This car does not get a lot of miles on it. It sits some times for a week at a time. Finally got the thing disassembled. (Used the old tried and true starter motor method.) Upon removing the lower belt idler pullies with the belt sitting there with no tension on it the tensioner snapped all the way open all of a sudden. It was bound up. New tensioner ought to do the trick. Trouble is the one that was on there was not that old to begin with.
I think the belt is loose because I removed the left inspection cover and discovered I could move the belt coming from the left cam (SOHC) up and down about an inch!!!?? Can't be good.
Using a starter motor to remove this bolt is an old trick I've employed in the past but was not even sure of the thread factor. Though left handed thread was a stretch I've never seen b4 I've never seen a hydrolic tensioner before on a timing belt! (Why rounded belt cogs?? Just to tempt fate??!!)
So what is the proper torque for reassembly?
Once again I must say your help is appreciated. Have a good day all.
Pilgrim
Trying to remove the harmonic ballencer to get the timing belt cover off!!?? Timing belt is loose and needs to be tightened up. 2005 H-4 non-turbo engine. What in the hell did they put the thing on there with a 550# pneumatic wrench!!?? What & where do we hold the engine so it don't turn over? Put it in gear with the E-brake on as tight as I dare and that did not work. Took the starter out and found a place to engage the flywheel gear then proceeded to bend a Snap-on 30" breaker bar!!!! Is it left handed threads? Anyone been here done this?
One of the things everyone SHOULD do when considering any vehicle purchase is pull sample VINs from similar rides you're interested in, then take them to your insurance provider. Suddenly a sweet deal might not be such... Realizing you're going to have to pay those costs year after year. Insurance premiums are a great indicator of real safety as the provider is EXTREMELY biased and bases their rates on the true cost of claims in the past. Their premiums are simply a matter of business.
When I purchased our '05 OBW I used this method and it worked well. When the agent looked up the OBW her reaction was one of disbelief! She wondered outloud how the premium of an auto in the price range of a new OBW could be so low. To me anyway that spoke volumes about safety comparrisons with other manufactures. The insurer base their premiums on ALL factors. In other words not just personal injury but costs of property damage as well as repairs.
Something to think about. She told me that it is surprising how many people don't even consider the cost of insuring a vehicle in their chioce of a new car. Pilgrim 54
hundreds of miles?!?!
that's a very common problem with the car, especially the turbo models.
i hope they filled up your gas tank when they finnished
when it happend to mine, it was just a simple re-programing issue, but i read about other people having that problem
if you're still under warrenty, get them to update your exu too, if you get nasty studdering/surging when you drop it into gear.. at about 2000 rpm... there's a hole in the fuel map there :cool:
or you could just get an accessport.. muha....
And we've had trouble with it since it was new. Had the reprogram et all...Living in the hills of western Pennsylvania we USE our OBW, 5M. We don't abuse it but we do our share of dirt roads out here. We miss it when it's not here but they did give us fuel and they ran it over a hundred miles not "hundreds of miles". The important thing is they think they found something. Thursday the 15th they're going to install the new switch so we'll have the results for you post that....Pilgrim 54
Sorry.. didn't read the whole thread, but with the 05's there's a few things screwy w/ the cruise control.
1) bring it to the dealer, have them update your cuise software & ECU, get all the newest fuel maps, etc...
if that's not it, and it's a manual transmission have them check the neutral position switch/washer thingy, it's known to come loose, and kick the cruise off.
when i got my OBXT the cruise would work for an hour.. then jolt and turn off.. and continue to do that, i brought it to a dealer, then updated the software, and it's all good now.
Pilgrim 54 here...Took it to the dealer and left it there for four days. They put better than a hundred miles on it and discovered that the neultral switch is malfunctioning as you described!! They did not have the part in stock and have ordered it. Will have it installed this coming week and will post the results. Thanks Jim
Boy time flys when you're having fun...Our '05 OBW now has better than 32K miles on it and things were going swimmingly when one day on an extended ride the cruise shut off... Over the past three of four months this has gone from a V E R Y intermittent occurance to the way it was b4 we had the "flash". Have had it back to the dealer twice now and been dealing with SOA as well but have been unable to get it to act up while the tech is in the car!!! Am bringing it in Monday 02/26/07 and leaving the car there for four days till Thursday. Just going to let them take it and drive it to replicate the problem.. Going through this crap all over again and SOA acts like they've never seen anything like this before!
It is UNBELIEVABLE that anybody could take such a poor interest in the quality of a basic function such as this. With all of the paperwork that we've generated and the fact that this is our first Subaru one would believe that they'd be upfront and proactive with a lasting fix. But no all they want to do is turn a blind eye. Pretend there is no elephant in the room! I'm reminded here about their choice of tires to put on an automobile that is designed to go anywhere at anytime in any weather. The BF Goodrich PE92s on the car were so bad I had them removed and canned them. They still had great life on them with 29500 miles on them. Why shouldn't they they're made out of plastic!! But I digress...
I know it does not sound it, but we love our car and use the AWD weekly having to travel a dirt road a couple of times a week. The car is solid, responsive (for the size of it) and comfortable. I would rate it's overall build quallity as above normal. Perhaps this is why this fundamental, now reoccuring flaw is so exasperating. What is truely aggrivating is SOAs reaction to this reoccurring problem. Why not simply take the bull by the horns and fix the thing without making us go through these ridiculous hoops and ladders!!! I must remember the tires...What a shame. Pilgrim 54
I'm not sure what the final drive ratio is on the newer legacies, but the highest that the legacies have had is 3.90. I'm at about 3000 rpm at 80 mph....give or take.
You won't really find a final drive less then that on most subarus (excluding the SVX).
My recommendation would be to see if you can get a higher ratio for just 5th gear. I'm pretty sure there are some options out there.
You may want to search http://forums.nasioc.com/forums or www.legacygt.com
80MPH @ 3000!!! Holy cow I'd leave that alone. Would love numbers like that. But as I say I'm turning 3300 RPM to get 70!!! That's simply too fast to expect decent mileage not to mention longevity. Certainly it seems that there must be someone out there who's addressed this problem.
Pilgrim 54 here. My '05 Outback wagon with a 5-speed manual is geared too low!!!! 70MPH is 3300RPM! That's simply too damn fast! Still I get 26-29 MPG But I know that I could do so much better if I could get the cruising engine speed down to about 2600. Already I'm using about a quart of oil every 1500miles and I'm not surprised at this consumption because of the Rs it's running. Has anyone out there got a fix? Are there trans gear choices? Rear ends would be cost prohibitive. For example what about using a 6-speed out of a STI? Is the 6th gear an overdrive? Seems hard to believe Subaru would use this low a gear in
Germany. There must be choices....
here is more info on what I discovered driving some 2006 cars. This applies to both at and mt trannys.
I drove an 06 2.5i auto and a 06 2.5i 5 speed. and have figured out what is different about the 2006 cars. When driveing down hill in a 2006 car, mt or at,
the cruise does not let the throttle come all of the way off. It holds the throttle open at about 5%. So on the same long down hill road my 05 lets the throttle off completely and the engine compression starts to slow the car to hold say 60 mph. When it hits 59.5 mph the cruise starts making rapid stabs to bump it back to 60 again and so forth. The 06 cars instead of thottleing back completely hold just a little gas on at all times thus the car on the same hill slowly accelerates down the hill but very smoothly. The end result is the 2005 car hits the bottom of the hill at 60 mph bucking between throttle off and on all the way down but holds speed well. The 2006 cars hit the bottom of the very same hill at 80 mph but the throttle never moved the whole way down . It remained slightly open with the instant mpg reading at 75 mpg where as my 05 instant mpg reads 99.9 inicating the trottle is closed. If the hill would have been longer I am sure I would have hit 100 mph in either of the 2006 cars. So if you want a smooth cruise that will not hold speed downhill buy an 06. Either way you have to turn the cruise off or you either buck and snort or speed down hills.
Pilgrim 54 here
After all these months since Thanksgiving I must admit that I've not been on-site much to keep up with the latest on this thread. Update on my '05 Outback 2.5i is that it's functioning FLAWLESSLY...still. Have put on about 5000 miles since the flash and it does not surge going down hills. Cruise is still functioning like a normal cruise. Don't know whether I just got lucky or what. Do not have the problem you're talking about with accelleration down hill. You have a problem that you should be able to replicate for your dealer. Accellerating down hill can't be called "performing as designed" if you ask me. There is a deeper cause.
Oh man its about time!!!!
I've been fighting with this problem, too. Did it also cure the bucking problem when you let off/step down while driving in lower gears?
Any chance you have the TSB number?
THANKS!!!!1
Andy
Just go and tell them to look this thing up. They are refusing to give me the TSB #. They're still acting like it's an isolated issue. This is a brand new bullitin so you'll have to ask them to check. But it's there and the fix works. If your dealer is a larger one they may be able to re-program the thing on-site. Good Luck!!!
Excellent, I wonder what they did? Any change in fuel mileage? It's probably a PID type controller, they may have adjusted it to be less aggressive with the throttle. My '90 Eclipse GSX had a mildly abrupt cruise control, the head of product development at Mitsu told me it was programmed for the non-turbo version, and was giving a bit more throttle than needed. It wasn't nearly as severe as this, and there was no real need to compensate.
They say they reprogramed the computer. In '05 they went to a drive-by-wire system. We test drove THREE new '06s on the lot and they ALL did it. I agree that it is a bad batch of computers hence not everyone is experiencing the problem. My mileage is quite good. 2.5i with a stick. I get 28-30 mpg though I admit I drive pretty conservatively. That has been unaffected by this change. They are being mum about the TSB #. I think they're frightend we'll cause a recall. You'd think they'd voluntarily want this stuff fixed!!!
I just bought a 2005 legacy 4 cylinder 4 speed automatic
and the cruise seems to be bucking when i go down hills.
Does anyone else have this problem?
Any suggestions?
Pilgrim 54 here FINALLY FINALLY Got somewhere with this issue!!! After 11 months. Learned to live with the surging but new problem developed. Cruise would shut off on it's own after being on 20 to 45 minutes. Once this happened cruise refused to stay on. Took it in for repair of surging as well. They offered to let me drive several '06s. I took out THREE of them!!! ALL of them had the surging problem. Two standards and one auto.
Don't tell me no one else has the problem. If you've not experieced this you'd have no justifiable input. This on/off again throttle is severe enough that it will make your head go back and forth. People riding in your car think you're spastic! While on a test drive I looked over at the tech and HIS head was going back and forth!! Sort of a Subaru wave going on here. The official response was "cruise working as designed". However the tech investigated his new Subaru Tech Assistance Bullitans and found A NEW repair for this problem. So go , children, pursue your dreams of a smooth, normally working cruise control. Tell your tech to look at the new survice bulletins for this issue has been addressed.
This problem was finally fixed by Subaru. They had to take out the computer and send it back to recallibrate it. They had the car over the Thanksgiving weekend. Gave us a rental. Now the cruise works well. Does not shut off. Does not surge on and off going downhill. As I put it , if you bought this car you'd not notice a problem with the cruise at all.
Please call or write to Subaru about your incidents. Without input from others they think nothing is wrong or what is happening is acceptable.
Please contact us at 1-800-SUBARU3 (1-800-782-2783), and refer to my case number 743944 to expedite your call.
or email directly to: SOAMail@sun.subaru1.com
cc to :
jmergen@subaru.com John Mergen
dmarshall@subaru.com Deloria Marshall
Maybe if we all write to them they will get the message.
The next step is to contact the CEO of Subaru North America, Mr. Kunio Ishigami.
Sincerely,
Gary Morgan
We have an '05 2.5i OW with a 5spd. The manual transmission really accentuates this problem. It must be related to the "drive by wire" throttle system. I drive an '05 Mack tractor trailer rig that is also a drive by wire system and the cruise control on that works flawlessly. You can tell you've got a problem when the factory tells you there is no problem. What we have here is a computer problem folks.
Rap Rap Rap They Call it the Rapper
Posted · Edited by Pilgrim 54
change format
'05, OBW, 4 cyl, 5sp, 54K miles started rapping on cold (15deg F) morning on start up. Never done this b4. Would last apx 5 minutes at which time it would get less and less till it disappeared completely. Was doing this everytime it started up with verying intensity, dirrectly related to ambiant temp. That's right. It never did it... Then once it did it, it always did it on cold start up only.
Took it to the dealer and was diagnosed with a bad T-belt tensioner which they replaced (on 100,000 mile warrentee).
Replaced the tensioner on maintenance 15 months ago when I discovered the belt was loose on the big turdy tousand mile service. Was surprised to find the T-belt loose but there it was. Since I was already in there I did it myself. You had a warrentee and u did it yurself?! Like I said I was already in there. I saw it as a chance to bond with my car... and I've been turning wrenches a long time... That's my story and I'm sticking to it... Yes, I used a torque wrench.
Replaced an Idler pully and the belt as well which I felt were SLIGHTLY worn but worn non-the-less by the slack. All this was ONLY 15 months and 15.5K miles ago after which the car ran great, smoother too, with no problem.
The Sube dealer, who did the work this time, found no other issues...nothing was lose...and replaced only the tensioner saying it was "beginning to freeze". The one I replaced was frozen and the engine made no noise; just caught it on maintanence. The end result is on cold start up everything's fine...noise gone...all's well.
QUESTION:
So what to f@*%? Is this going to be a continuing saga? I can't believe with all these like built engines runninig around that I got two defective tensioners?! How common an issue is this??!! The first tensioner let go @ 38K/2.75 yrs and the second just 15.5K/1.5yrs latter? I guess I'll have to start pulling a belt tension inspection every 12K? Hell the new WRX uses a couple tensioners and variable ones besides to achieve their variable valve timing if I'm looking at the picture in the Performance mag correctly! EAGADS, I'm glad I don't have to deal with that complexity! So are these tensioners messing up with this kind of frequency for others out there or am I just lucky? PILGRM
