mday
Posts posted by mday
Hi, I am a new user and did my homework by searching for a previous post about a car identical to mine with the identical problem: for about the past year, my 2000 Outback with 48,000 to 57,000 miles on it has very occasionally had the AT and CEL come on flashing and gone into what some have called "limp" mode with very hard shifting. I let it rest and it's usually fine. The dealer, of course, said no codes were readable and laughed at my request to have it consdered under warranty, since, as far as he knew (he rode in the car for 25 stop-and-go-miles and of course the problem would not recur) the car had no problem. Have there been any updates on this problem, and, beyond trying to read cryptic codes, can someone give me straight advice on what to do to fix the problem?
Thanks!
Michael
MTX,I can bet $10,000 your codes are p0122 and TCM31. Faulty TPS, effects both engine and AT management. Please use palpay to email me $50 for "remote" OBD2 scan.
But seriously, I had the same problem in my 2000 sub with 45000 miles.
Note that AT temp light was blinking only. That means AT detected problem and went in limp mode (with hard shifts, etc). Only solid AT temp means overheating. There ia actually a procedure for pulling AT error code without scan, see below.
Now is the bad news.
I was charged $330 for replacement of TPS by dealer. $240 for a simple potentiometer, bloody murder! I was actually surprised that this was not covered by powertain warranty. The replacement took care of the problem but for a couple months only and it sometimes comes back in an intermitten fasion. I am afraid they replaced perfectly good sensor and the problem is with connection or wiring. Now I am wiser and invested $88
in OBD2 interface. The TPS is OK but O2 sensor has weird readings, sometimes it works, but often a flatline 0.5-0.7 V. I guess I will replace it. I do not know if TPS and O2 problems are related.
Below is what I found on one of the internet forums, it works for 2000 legacy:
"In any event, the flashing AT Oil Temp light indicates that the Transmission Control Module (TCM) has detected a problem and is trying to tell you about it. Here's the procedure for interrogating the TCM (...). It's one of those secret handshake procedures reminiscent of the pre-OBD ECU days. I swear I'm not making this up.
1) Warm up the engine
2) Turn the ignition switch OFF
3) Turn the ignition switch ON
4) Start the engine
5) Drive the vehicle at speeds greater than 12 MPH
6) Stop the vehicle
7) Depress the brake pedal and move the gear selector to "1"
8) Turn the ignition switch to OFF
9) Turn the ignition switch to ON
10) Move the gear selector to "2"
11) Move the gear selector to "1"
12) Move the gear selector to "2"
13) Move the gear selector to "3"
14) Move the gear selector to "D"
Now examine the AT Oil Temp light again:
If the light's blinking 4 times a second, then the problem is most likely a power supply or ground problem.
If the light's blinking 2 times a second, then the TCM believes all is normal.
If the light's on solid or not on at all, then there's a problem with the light's circuit.
If the light's blinking with one or more long (1.2 sec) pulses, followed by one or more short (.2 sec) pulses followed by a 1.5 sec pause, then you're seeing a TCM diagnostic trouble code (DTC). The long pulses indicate "tens" and the short ones indicate "ones" so you add up the number of long pulses to get the left digit of the DTC and you add up the number of short pulses to get the right digit of the DTC. DTCs are two digits long (e.g. 23, 36, etc.). The end of the "ones" is indicated by a 1.5 second pause. Then, if that is the only DTC stored, it begins repeating that DTC with the "tens" again. However, there may be more than just one DTC stored, in which case they are spit out sequentially with 1.5 sec pauses between them, until the whole sequence repeats again."
Check Engine / Intermitent AT Temp Light
Posted
Hi again,
Yes, you were right. The TCM is flashing out 3 longs and a short, the 31 error code for a faulty TCM, right? And the TCM is listed as covered in the powertrain warranty. Although it's out of warranty now (over 5 years since purchase), since I first took the car to the dealer within the warranty period, would it not be fair for me to request that they replace the TCM at no cost? I have a feeling that the dealer will say no, but I believe that I then have a case to take to SOA if they do say no.
Do you know of any statistics on the frequency of occurence of this problem?
Thanks,
Michael
