RudyTudy
2
Posts posted by RudyTudy
It's all good, I went back under the 2.2 and adjusted parking brake right. Took about 10 clicks on each side. Had car off the ground using my new 3 ton jackstands from Harborfreight with safety pins ,$44.99. Way better than other two I got.
- 3
- 1
Thank You for informing me of my ineptitude of Subaru's technology and mechanical engineering. I'm always trying to do things fast because girlfriend's on the way.
- 2
I've done both adjustments, however I didn't turn Star enough. I'm going to try again. The first time a couple months ago, I was turning and turning and I'm thinking how does this tighten cable for disc brakes ? So I stopped.
Thank you for this information on the parking brakes. Found it in manual, I've tried adjusting them with no luck. I didn't know about them hiding inside the disc brakes.
4 hours ago, RudyTudy said:
Yes,as tight as is possible, no parking on incline turning toward curbs.
I'm hoping that's all. The parking brake cable is stretched and doesn't work. I got new tie rods installed, I installed new CVC axles, replacing right wheel bearing. Parking brake cables next ?
96 Automatic Outback has 2.2 was 2.5. When I park and put it in park, turn off ignition, the car moves forward a little. Why ?
Blinking AT TEMP LIGHT
Posted
I seen a thread or topic or comments about Tranny Temp Light flashing on start up. Can someone post that or share to me or point me in the right direction. For 96 Legacy Outback Automatic Transmission. Thanks RudyTudy
