Devans850
  1. Ok so this is where I’m at. The flywheel is not the original flywheel and has no marks on it at all, because it was replaced for a prop hub. The only timing marks to be found are on the camshaft sprockets themselves. Is it possible to set the timing from TDC? I know there has to be a way to set the timing without the flywheel marks on this motor, but I haven’t figit out yet.
  2. I checked the inner sprocket multiple times after cleaning it good and I’m just not seeing a mark on the sprocket. So I’m at a loss.
  3. Ok cool. I will definitely check that!
  4. I don’t see any marks.
  5. Is the keyway on the crank sprocket the timing mark?
  6. Devans850 joined the community
  7. Looking for help on a timing issue for an Er27 motor. I had to replace the timing belts and now the engine won’t crank. The motor is on an airboat and there are no timing marks on the flywheel and not sure what to do. The can sprockets have the timing marks, as do the covers. Any help would be greatly appreciated.
