dadfulltime
  1. I see there are some other threads on this subject. Excuse my bumbling. I'm new here. I am getting ready to do timing belt, water pump and check valve clearance on my 97 outback. If you have done this job, ANY advice is appreciated!
  2. Thanks for your reply! I am simply checking the valve clearance. Part of the 100K. I have done this job on many other cars with only a feeler guage. But the '97 Outback uses removable shims. The tool the attaches to the camshaft and depresses the bucket so you can reach in a pull out the shim. Have you done this? Is the tool totally specilalized to the '97 Outback?
  3. Thanks for your reply! I am simply checking the valve clearance. Part of the 100K. I have done this job on many other cars with only a feeler guage. But the '97 Outback uses removable shims. The tool the attaches to the camshaft and depresses the bucket so you can reach in a pull out the shim. Have you done this? Is the tool totally specilalized to the '97 Outback?
  4. I want to check the valve clearance on my '97 Outback. The Haynes manual shows a special "valve adjuster tool" on page 1-29. Says the job cannot be performed without it. They have it at Kent-Moore for over $200. Does anybody know of a cheaper way? Is there another more common tool out there that works?
