Everything posted by globochem
Large Gap in the Exhaust Pipe to the Intermediate Pipe
As a temporary measure I just got a universal bracket to hold the pipe in place. I'm still having trouble with my exhaust, though. I've been able to attach the hanger, which helped with the sag in the connection, I replaced the gasket and the bolt set. I don't see any holes on the pipe but after the engine is running for about 90 seconds there's a smoke that comes off the pipe around the flange. It looks like the smoke is radiating from the pipe just before the flange on the manifold side. I tried using soapy water to see if I could find any bubbles but I'm not seeing anything. It doesn't seem like it's an oil or any other sort of liquid that's burning off because it's always done this since I got the car a couple months ago. If there was any residue I figured it'd have burned off by now, especially after I've wiped it down. There's no smoke coming out the tail pipe, it's just around that connection between the exhaust to intermediate pipes. Any suggestions of what to look for? I've been using a thermometer and it doesn't seem like anything is overheating, everything is in range as far as I can tell. https://drive.google.com/file/d/15sDwiU7-1OyZq7SzNpBhi5cRXYKuRaKj/view?usp=sharing edit: and one other thing instead of starting a new thread... Apparently the transmission is supposed to be grounded and I've got this black wire just hanging loose. I'm wondering if this is the ground wire and if it's supposed to ground to this spot since it seems to be just the right length: https://drive.google.com/file/d/166thpiZb3AhqsFjT47-IHUJOek_bpj4j/view?usp=sharing
Thanks for walking me through the mounting bracket location, I was making it way harder than it needs to be and I think I've got that situated. I'm still having a problem with the exhaust where the pipes meet, though. I've got a brand new gasket in there but it's leaking in the same way that it did before I changed the gasket. I don't see an issue with the pipes like a crack or hole, so I'm thinking it has to be the connection. Does anyone know the correct size of the bolt/spring set that joins the flanges together or does it not matter as long as there is a secure connection?
That's super helpful, thank you. I feel like I'm close to solving this mystery. In that first image is there one or two bolts that attach to the transmission? Do you know what size they are? Another forum presented this parts chart: https://imgur.com/qu43AD3 Based on what I'm seeing on the transmission and the images it seems like it'd be No. 4 but if I'm reading that right it's for an Automatic and I've got a 4WD Manual.
Man, I'm just not seeing it if it's there. I can see on the exhaust pipe where the bolts would attach to a bracket, you can see it in the first image, but I don't see where the bracket would attach to anything. I'm wondering if the bracket rusted off at some point and this sheared area is what's left: https://drive.google.com/file/d/11zdb1sjc_dODNp6YoLSoJigjvWzudY8K/view?usp=sharing Google Image Search has some nice shots of the underside but I haven't seen anything with high enough resolution to really see what's going on. Thanks for the insight on the donut, that makes sense.
Working on a 1985 Brat, I had a huge exhaust leak at the connection between the exhaust pipe after the converter to the intermediate pipe before the resonator, so I figured I'd replace the gasket and also try to address the sag in the exhaust system which probably caused the leak in the first place. I inserted the gasket (Fel-Pro 60566) and bolted the pipes back together but this just seems like too big of a gap. This model number is supposed to fit an '85 Brat but it just doesn't seem like the tightest seal to me. I'm new to this so maybe I'm missing something but does this look right? Driver side angle: https://drive.google.com/file/d/105GyNzLpYFJoks3KG9s_aT19iXtZzf50/view?usp=sharing Passenger side angle: https://drive.google.com/file/d/1t7cSIzs9kHmFQHRBTQv4jEOzX9f-xZnl/view?usp=sharing Additionally, where are the exhaust hangers supposed to be on the frame? I'm only seeing one near the rear axle. I don't know if the others rusted off or what but someone before me just wrapped a piece of wire around the pipe and the sway bar: https://drive.google.com/file/d/11u0OvjgNDVYK-dmv_C4Y7_S13niNH4HD/view?usp=sharing Thanks for any tips.
1985 Brat Exhaust Manifold Gasket Size
I got a set of 44022GA330 exhaust manifold gaskets, which supposedly is a fit for the 1985 Subaru Brat, but the ring on the inside of the gasket is a bit wider than the pipe and the engine. It's also wider than the old gasket that I pulled off of the exhaust. The bolt holes line up but the ring size isn't an exact match of the pipe size. Does this sound right? I see that there is also a 44022GA340 that is also a fit for the '85 Brat, what's the difference? The listings I'm looking at say that both are a fit for the 1.8L H4 - Gas engine. Edit: Apparently I'm not alone in getting fooled by the part number. I ended up with part 18535 from Detroit Gasket. Other model numbers are Fel-Pro MS91075 and McCord MSF265-1.
