joshsmith3662
  1. I am looking for a standard 5 speed transmission for a 2007 Outback basic. It has a sticker that says TY757VCDBA. Mine is showing metal, noisy and is hard to shift into gear. I changed the fluid. It has new throw out bearing, master and slave. When in gear you can still move the shifter back and forth like it’s in neutral. Can I rebuild this and if so any hints on where to find the parts? Any information is appreciated thanks!
  2. Thanks for the info guys! Yeah I figured it might be like that. Awesome! Thanks for your help!
  3. 2007 Outback legacy is it easier to drop the transmission to change the clutch or pull the engine? Odd question maybe. I can’t find any information on the weight of the 5 speed manual that’s in the car. I don’t have a lift but i do have a cherry picker. I’m just not sure if I can get the car high enough to drop the transmission. What have you guys done? Thanks
  4. Hello thanks for reading! I have a 07 Outback with an ej25 that has bad crank bearings. I picked the car up for 300 bucks and want to get it going. I found a avls sohc non turbo jdm that u want to put in it. Anyone have any tips or suggestions? I’ve searched the web but haven’t had much luck. The car is in beautiful shape for the age and mileage, would like to see it running instead of going to scrap. Thanks again!
