storrey
  1. In the back of my mind I remember hearing that you can check the fuel injector circuit with a dwell meter like used to set points on an older car. Does anyone Know how to do this?
  2. How do I check the injectors? This car has 3 injectors into the intake manifold not one in the throttle body. Thanks for your advice. storrey
  3. I have a fuel injected 1990 Justy. Sometimes it will not start. I am fairly sure it is a fuel delivery problem. It will start and run fime if I spray starting fluid through the throttle body. I installed a pressure guage just ahead of the fuel rail and it reads 40 psi. The preasure is the same when the car is running or when it is shut off or when I am trying to start the engine. Is 40 psi enough pressure? or any other suggestions would be helpfull.
