Everything posted by jrbuckingham
Trans Cooler
I'll look at the different types, Hayden has one # 402 that is $33. Which model did you use wher the fan did not have come out? Jim
Trans Cooler
Thanks for the advice, buying one today. Less inexpensive then a trans! Jim
Trans Cooler
Are there simple written and visual instructions for the install?
Speed-O-Meter
So sorry about the late reply, it turned out to be a much bigger problem to trouble shoot. It ended up as a bad board behind the inst. panel, which was much cheaper then a speed sensor to buy and install. Thanks Jim
Trans Cooler
I have a 99 Legacy w/2.2 & auto trans w/82,000. I had a total trans flushed at 70,000. I will be towing a small u-haul trailer from AL to CA, is it recommended that i install a small type cooler? Thanks Jim
Towing
Have 99 2.2 auotomatic Legecy L S/wagon w/tow hitch, is it possible to tow small(u-Haul) trailer w/out damage to drivline? Have kept up w/all service, trans flush,new brakes, new tires oil changes etc. Thanks in Advance Jim
Maintenance Log
Not what i was looking for, that was a dealer generated reminder. I was looking for something more simple where i can keep on my desktop and add my own info. Thx Jim
Maintenance Log
Is there a FREE maintenance log available for download to be used for oil changes, tire rotations etc or? Thanks Jim
Brake Job
Starting a f/brake job on 99 2.2 auto trans Legacy w/15in wheels; anything special or nasty things i should be on the look out for. I'm very thorough & want to do thejob right the first time. Thanks & ALOHA Jim
Speed-O-Meter
Speedometer perperiodically does not work; 99 Legacy S/W w/2.2 & auto trans, also need to find good shop manual for same veh. ALOHA JB
