d1camero
  1. I have an r160 from a 1995 Impreza. I am just bead blasting it, and want to remove the pinion before getting it full of grit. How to the pinion come out? The pinion nut is off. thanks d1
  2. FYI - it weighs 45 lbs with no inner CVs. Distance from output centre to pinion face is 400mm d1
  3. I am building a lightweight sports car from scratch (1500lbs) and I am not sure if I want to use a Miata 1.6 rear end or a Subaru R160 rear end. I have some questions and the R160: How much does it weigh? How long is the pinion from the axle centreline to the pinion flange? Can it easily handle 210 ft-lbs of torque? If anybody has other recommendations for a light weight, IRS differential, I would appreciate hearing about it. thanks Don
