mazzy111
Posts posted by mazzy111
Well, looks like I have found someone with a similar problem. At 140,000 miles Exhaust valve on Cylinder 4 has zero clearance and I suspect the valve may be cracked in half. Can anyone confirm that a broken valve would cause this? It seems to me that if the valve wasn't seating, the clearance between the shim and cam would be higher than the spec, but I have the opposite.
Suggestions? Rebuilt engine? Valve job? Valve job and head gasket?
Please help!!!
Blown head gasket...now what?!?
Posted
My check engine light is on at 140,000 miles on a 97 Outback. In check in the valve clearances, an exhaust valve for cylinder 4 has zero clearance at all cam shaft rotations. Is the valve likely broken/cracked/stretched? Is the seal worn? Please advise on likely cause and solutions.
From reading through the forums, I understand that the head gaskets are a problem as well, so perhaps a head gasket/valve job is in order.
Help!
