Top mount pics, 89 rx
Posted this awhile back and was asked for some pics of the brackets. I am redoing and rebuilding a few things(new thread on that later!) so I got some pics of some of the hidden bits.
Pretty straight forward stuff, ebay ic with new brackets welded on and tabs welded to the chassis. Rubber mounts between brackets and ic. Ic is mounted as low as it can possibly go. I have a scoop on the hood, I plan to shroud the ic and shield against the turbo.
Sam
Edited by bluto5
clean but you will idle smother if you unplug the iac & plum it in to the boost
Thanks for the kind words and the advice.
The whole thing is pulled down for rebuild now and just about every thing has been worked on in some way or another. I will post some new pics once I make abit more progress.
Sam
