HVAC Bulbs :: Panel Removal Help Needed! [picture]
96 Subaru Impreza Outback ... I've got at least one (if not more) bulbs out behind the HVAC. My fan speed knob doesn't light up, whereas my temp and location knobs are nice and bright and the little green icon at end of knob illuminates too.
So I'm guessing it is just a burnt bulb or two (you folks agree?) I'm looking at my dash (see pic above) and don't see any removal screws. I'm assuming the panel just snaps in, and a trim removal tool would be best to pop this panel out, correct? Want to make sure before I break anything -- so if anyone has any pointers to remove panel above please advise!!
Thanks in advance...
[[ UPDATED ]]
Okay I figured it out ... turns out there were two "hidden" screws at the 12 o'clock position on the far left/right knobs. Unscrew those, and a good yank to pop out the vents and lower-trim as a single piece. Then there are two screws that hold the knobs control in place, but I didn't need to unhook it. Just enough room to twist and pop out the bulbs.
Bummer now is that the bulb is super small wedge-stlye LED-esque little bugger. Nobody local I've called carries them. I'd doubt Radio Shack even carries it as their website shows nothing similar. Dealer wanted $6.50 + tax ... so I went ahead and ordered that. Should have it in a few days I guess. Bahh humbug!
Edited by Shaka
because editing is fun
I don't know exactly how the panel comes out, but, it probably is a snap fit. Hopefully someone else will see this post and chime in. Just be careful not to mar the edges of the panel or dash with the extraction tool.
Should just pop out with a plastic trim tool or similar.
I have a small curved pick tool that works great for this kinda stuff. Just nudge it in, turn it 90° and give it a tug.
