5sp single range in first gen BRAT?
I was perusing the local JY a while ago and found a first gen BRAT that was
still original, rusty but original.
The jumper's were still welded in from the factory :eek:
But, anyway, back to the point, the shifter knob indicated it was a 5sp, but it
still had the old style 4WD lever under the dash.
So, just to make sure nobody had screwed with the shifter knob, I played
with the shifter to see what gears it actually had.
And HOLY SHNIEKIES it had a 5th GEAR!!!!
AND it had 4WD!!!!
So, my questions are,
1 was this an option from the factory,?
2 is it possible to hook a mechanically operated 5sp s/r to the stock linkage?
3 did a mechanically operated 5sp s/r even exist?!?
And if they still have it and I have the funds and time, I WILL be going back
out and pulling that tranny just save it from the crusher.
Twitch(ing with excitement!!!)
I have a buddy of mine that had a 1979 Brat for years (before it was side-swiped and ulitimately sold as a parts car -- sad story). He had swapped a 5-speed into it, but it also no longer worked as a 4wd. Don't know the full story, but if you like, I can give him a call and find out.
So, in short, there was at least one gen1 with a 5-speed in it Frankensteined together that I know of. Don't know if this helps or not...
  • 2 weeks later...
