suby92 Posted January 19, 2010 Share Posted January 19, 2010 Clutch cable 1992 Legacy. Does anyone have pics of how the clutch cable is supposed to go at the top of the engine? Trying to replace an old cable and having problems getting clutch to engage -- want to make sure I have it threaded correctly. Bought a Subaru OEM part online, different than what was in prevoiusly. Thanks : Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 19, 2010 Share Posted January 19, 2010 I don't have a pic but I can try to explain it. The end with the threads should have a few conical washers or spacers, with a rubber bushing and then two nuts. The washers sit in the cone shaped recess on the release lever. The cable is run back towards the firewall through the cable mount on the transmission. There should be a rubber bushing on the sheath of the cable that fits into the holder on the trans. It might be a tight squeeze but it will press in. From there it runs down and loops around to where it goes through the firewall. Where did you order the cable from? Did you double check the part number on the part you got with what is listed for your car? Link to comment Share on other sites More sharing options...
Gloyale Posted January 20, 2010 Share Posted January 20, 2010 Make sure it is routed UNDER the steering shaft. Link to comment Share on other sites More sharing options...
suby92 Posted January 20, 2010 Author Share Posted January 20, 2010 Thanks for the help. Think I have it now. Bought it online from a "genuine OEM website". charge came through as Stadium Inc dba Lees Summit Honda. They did ask for the VIN number. Speedometer cable purchased at the same time was the correct model. Thanks Link to comment Share on other sites More sharing options...
