February 21, 201016 yr hey so my gl is doing somthing that i have never seen. so the other day i went out wheeling in the sub, when i was tillted in a downword postion it starts blowing smoke out the exhaust and burns alot of oil, then when i drive a mile or two it stops smoking, any ideas.
February 22, 201016 yr it sucked oil up in the pcv system. take a fast, sweeping right turn and io bet it will do the same. consider replacing the PCV valve if it keeps doing
February 22, 201016 yr The right turn is what does it for me, Subaru a long time ago even offered an "upgrade" to fix that, which is just a larger tube going to one side of the PCV to not make it suck in the oil. I keep one of my cars that way so I can "James Bond" my freeway entrance. I've successfully shut down 4 lanes of traffic, and haven't clogged the catalytic yet. The engine bog kinda sucks, but no one is really catching up to you, as they can't see.... Heh.
