March 20, 201016 yr I have a 94 loyale and the fuel lines are leaking in the section of line running along the rear of the wagon, what size lines are they and what type (size, etc.) of fitting is it? The local dealership wants 500$ to do it.
March 21, 201016 yr I have had mine rot a ton of times.... They are not that sophisicated......... I can't help you with size.. can't remember... but it is fairly simple job... their is a weird cannister on some of the lines near the pump.. usually the canister rots out..... Just replace it with regular line....... I live in the salt region........ these cars rot out big time......... I use por-15 rust paint on the lines... I sop the whole underneath of the car..... Otherewise I would be replacing this stuff all the time. I even had a fuel pump rot out on me..... that was 400 bucks.... probably 10 years ago.... so I paint everything under there.... fuel lines brake lines suspension.......... Don't give the dealer your money....they don't deserve it.......
