What are these two wires under the ignition?
I see a blue and a yellow wire. The hatch i just bought has a ignition hack job that im trying to fix. but i cant figure out where these two wires go. blue/yellow. it looks like they were cut for some reason. Help?
If it's blue and yellow with a pink connector it's for the door speakers.
It's common to cut them and splice in new wiring to the front speakers. You kinda have to to install an aftermarket stereo, becasue the stock wiring is common grounded between front and rear speakers on each side.
Hi, its for the key dinger, a sensor in the ign switch lets you know you have the key in the switch, those wires connect to the tiny switch sensor at the opening of the ign switch. if they hacked the switch they broke it most likely.
Thank you everyone. Makes me feel better that it's not important or anything! Lol I'll tape them up then.
