April 8, 201016 yr got my ej20 heads and my buddys 2002 ej25 motor and feeling like frankenstein any advice first hybrid ive done. i also have my stock 97 ej22 and 94 ej22t motor for parts. any advice please
April 8, 201016 yr You need to check what the compression ratio is going to be. Is this going to be a turbo or non-turbo motor?
April 9, 201015 yr Author turbo.....the compression will be a little high but ill comp with dished pistons or thicker head gasket.
April 9, 201015 yr I don't have any direct help, but you may want to search ask in the built motor forum on http://forums.nasioc.com
