January 8, 201115 yr Author Yup, the EJ22 is fitted and running perfectly. Using a Weber 32/36 mated to a modified EJ18 manifold. Am also using a 1996 FWD Impreza gearbox which has the correct spline count for the EA81 front half shafts. The gear linkage worked fine and i made up a custom clutch cable. Have built a custom exhaust for it, added some wheels, done a little bit of tuning and once again have a running car. http://www.youtube.com/watch?v=4XIWzcWpZg8 Next battle is to fix up a couple small rusty spots and lower it.
January 8, 201115 yr Author Used a distributor from a EJ18 and im still using the EA71 coil. All seems to be working nicely
