April 28, 201015 yr Can I make this swap work? I have a 5/96 Legacy Outback with a EJ25 and need to find out if I can use an engine from a 2002 Forester 2.5 SOHC. The exhaust ports on the head are the same, but no EGR system. How will the engine wire harness mate up? Please help with any onfo.
April 28, 201015 yr This is not at all a direct swap. It will not plug in. The intakes are not interchangeable. You'll get a check engine light for the EGR system not being compatible (you'll get two codes for that). Not sure what you're looking for, but this is more of a project than a direct swap. All of that info is already covered here, like which years swap and the differences.
April 28, 201015 yr Author Thank you for your help. I tried to find the info on here but I'm not forum savy at times.
