May 11, 201015 yr Are there any other years that will match the mounts or atleast close to it. I would like to put the spring loaded style on, just have no idea where to start.
May 11, 201015 yr Easiest thing to do is make a bracket that adapts the late ea82 rear coilovers to the stock shock mount, then disable the torsion bar. Fitting the entire rear assembly from a ea82 car can be done, but only If you plan to lift it and make adapter blocks, or do some custom fab work to reconfigure the mounts either on the body of your car or on the ea82 subframe. -Bill
