Searched ! running out of time Oil Pump?
Started out as just a front engine reseal. Cam, crank and oil mounting gasket.
Got every thing back started the engine smooth good oil pressure no leaks. then no pressure and noise from valve train.
The question is on the oil pump there is a letter B stamped on the two moving parts do they have to be on the same side together or dose it matter?
