June 23, 201015 yr I need to swap out a defective AC compressor clutch on my '92 Loyale. I was able to remove the retaining nut, but can't budge the rest. It appears that I need to next remove a retaining washer using a spanner wrench. The washer seems to be threaded into the same shaft as the nut and has two holes approx 1/8 in. that accomodate a spanner. I can't find one anywhere, so tried to fashion my own. I can't budge the thing and just managed to bend the homemade tool. Does anyone know how to disassemble the clutch from the compressor? Does it take a special tool? Any help would be appreciated. Thanks in advance.
