Block heater
I have a 2003 Subaru Baja, I found a plug located next to the oil filter is this the correct location for it. Thanks
Edited by mjb52
If its a dealer one its usually on the other side of the bottom of the shortblock, on the other side of the oil pan. The plug is bigger than that one but has the same size socket hole in it. These can be pretty tough to remove sometimes. Its a 14MM hex if you don't have the right socket don't try removing it.
