baja lift help
ok ive had no luck finding a 2 in lift for a baja so i guess ill have to make one
does anyone know how to figure out the angles for the front strut blocks so when i lift it the camber angle stays the same
Do some searching on the ea81/ea82 lifts, as the dimensions are posted somewhere. I think its some 1.5 inches for every 3 in of lift. I am not sure, but it may be something you can do some math to calculate. Otherwise the suspension geometry should remain the same relative to itself.
i know at least two members on this board are making them. Baja strut tops are outback stut tops, since the baja is a .5" raised outback with a new skin. Front ends are identical :)
