Rack bellows repair
It seems they break at the neck. (Like clockwork every 15 yrs;)Then before all the snow and salt U don't want to take stuff apart yet leave this open.
Junk baby! Tophat plastic bushings. It actually does work. The inside one should be fair rigid. A flare > 1" . The ID is about 5/8" Saw the bush/isolator and wind it into the bellows. Drawn back into spot another with the ID of the 1st's OD is slid over it. All at that point on the rod and screwclamped. Worked fine for 1 1/2 yrs with extremes.
