a/c delete
turbo or non?
order belts for a non ps, non ac, 1986 1.8 gl ohc.
There are 3 belt sizes. you will be using the shortest of them. The shortest belt is the one already on the outside pulley. just have 2, and you can get a dual pulley for the alternator.
The trick will be mounting the alternator with no ac. You may have to salvage the ac bracket and use a threaded rod for the round compressor(outboard alt), or use the square compressor's mount(inboard alt)
easiest thing to do is find the alt bracket from a non ac model, and retrofit. use the shortest belt
