MY RX Project!
Plan is to gut my RX.
PIC as of now with 6 bolt conversion.
bone stock AWD/AT 1.8 EA82T
Gut out my lifted 86 GL wagon
Install all parts from lifted wagon into the RX.
Finished project should be like this mod list.
SJR 6" lift
EJ22T with EJ20R heads and turbos
turbos running parallel
WRX intercooler
38mm external wastegate
4 bar MAP sensor and boost gauge
86 GL instrument cluster MT
Front legacy SS calipers and steering knuckles
rear xt6 control arms, hubs and brakes
xt6 brake master cylinder
megan racing coilovers for 05 outback
4.1 legacy trans and rear diff
17x9 cobra replica wheels powdercoated candyred
5x100-5x4.5 wheel adapters
innovate wideband
dual thrush exhaust
255 LPH external fuel pump
adjustable fuel pressure regulator
850cc five o motorsport injectors
ACT stage 2 pressure plate with kevlar disc
link G4 ecu
Should be fun lol
Edited by roostema4328
ha ha. Im not. You found a typo. lol I will fix. 5x100/5x4.5 same bolt pattern as jeeps or ford rangers. more wheel options in that bolt pattern. all the 5x100 offerings are positive offset.
If you look at the wagon above. It already has the wheels and adapters on. those are transferring over. you can see that they are 5 bolt. haha
going to start parting out the wagon this weekend. then haul away the body and start stripping everything out of the RX. the original rx trans and engine will be for sale if anyone is interested.
I want to say thank you. A while back we got into a huge debate on if that wheel would be even worth the swap. I was looking into lowering my wagon and was geting advice on doing the 6lug swap and useing the aluminum chevy 6 lug wheels. That looks great and if i ever lower a subaru i will be going that route. Good luck on your projects.
yeah it looks great. It looks even better in person.The offset of the wheel fits perfect it has 1955516 tires on the wheels. It looks almost factory. The only drawback to them is that the center hole in the wheel is too small to fit. You have to grind all the original tabs that are on the hubs that centered the original wheels flush. That takes a while. but the end result is awesome. those wheels and ws60 blizzaks. only took 1.25 oz of weight to balance the whole set. oe wheels are always way better quality than aftermarket.
