eryque Posted April 23, 2011 Share Posted April 23, 2011 2002 OBW, 2.5L... I tried to pull this hose out of the way and the lower fitting broke off. It attaches to a plastic piece that's underneath the ignition coil, underneath the intake manifold. I've tried identifying it in the Intake/Induction system diagram and can't locate it. It draws a vacuum while only the upper end is connected, and with the lower end disconnected my idle is a little high. Can anyone help? I'm guessing I'm going to have to go to a dealer to find the part. Thanks in advance for any help! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 23, 2011 Share Posted April 23, 2011 Looks like it's for the Evap purge valve solenoid. If the line goes to a T you can replace it with a generic T from a parts store. Probably goes to this little bugger though which is going to cost some $$ from the dealer. http://www.subarupartsforyou.com/cp_partdetail.php?partid=15215 Get one from a junkyard for $5. They don't often go bad. Quote Link to comment Share on other sites More sharing options...
eryque Posted April 23, 2011 Author Share Posted April 23, 2011 (edited) That looks like it. I'll call the junk yard tomorrow, and try to see if I can repair it somehow before I spring $85 for that little thing. Edit: I searched on that part number and ran across a thread on NASIOC where folks posted that they fixed it with JB Weld. I'll give that a shot first. Edited April 23, 2011 by eryque Quote Link to comment Share on other sites More sharing options...
