4EAT Pinion Bearing & Gear Removal?
Yet another question about Forester front diff repair....:rolleyes:
I've figured out how to remove the front diff case, the tailshaft case, and then the pinion. However, the large drive gear that the pinion shaft slides into (at the back of the transmission in the tail area) is staying put. I want to pull that gear out and replace that pinion bearing with the front bearings. How do I get that gear and the bearing off?
Just in case, has anyone removed the bearing from the output shaft/pinion drive gear from the transmission, too?
