EA81 Carb Issues.
Hey guys I am having some issues with my carb.
It will start and run perfect when the engine is cold and idle perfect but once it runs for a little bit and warms up it will not idle it all and just dies.I can usually start it back up and it will rev just fine but will not idle. Every once in awhile though I will try to start it and it just cranks like it is flooded or something. What could it be?
Edited by Resortx
mine does that too. similar anyways...it idles at around 200rpm once the choke is off. I can't quite put my finger on what's causing it. I know that if you turn the idle mixture screw in to almost seated, it'll bring the idle back to normal. but that's really not a good idea. to get by, you can turn the idle speed up so that it doesn't die all the time.
I gave up on it, and just deal with it till I either A.get a weber, or B.do a 2.5 swap
Yeah i've thought about doing the spfi swap but ill probably just pick up a weber and get rid of some of that vacuum
