czaray Posted July 2, 2011 Share Posted July 2, 2011 Hi all, I have a 93 subaru loyale and I adjusted the clutch and now it won't start. I tried adjusting it back and all it does is make clicking sounds. I have been reading the threads and people say it is because of the clutch safety switch, but I do not know where the clutch safety switch is, or what it looks like. I would rather not bypass it, but will if I have to. But then again, I don't know how to bypass it. Any help would be greatly appreciated.:-\ Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 2, 2011 Share Posted July 2, 2011 maybe you have a loose cable near the starter. Check the battery terminals, etc. Perhaps it is a coincidence that the starter went out at the same time. The problem could lie in the ign switch in the steering column. Easy to get at. you can jump a wire from the battery to the spade terminal on the starter. If it clicks, the starter needs service. If it turns, the ign switch needs service. Deterine this after first checking the cables. Quote Link to comment Share on other sites More sharing options...
czaray Posted July 2, 2011 Author Share Posted July 2, 2011 I will have to check it tomorrow it is getting late here. I'll let you know how it goes. Thanks Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 2, 2011 Share Posted July 2, 2011 Check the signal wire on the starter. Good chance you might have knocked it off. Quote Link to comment Share on other sites More sharing options...
czaray Posted July 3, 2011 Author Share Posted July 3, 2011 Yes, it was the battery cables. Cleaned them and started right up. Quote Link to comment Share on other sites More sharing options...
