March 10, 200422 yr Does anyone know which years might work for me if I need to replace the auto 4WD transmission? I have heard conflicting reports from a variety of sources: some say '90-'94 work and others say only '90 and '91, and '93 - '95? it is non-turbo and 2.2L Legacy L Also - if the '93-'95s might work do they have to be 2.2L? or can i swap one in from a 2.5L? thanks - Bret
March 10, 200422 yr they'll pretty much all work. The electronics have changed a little from year to year in how the TCU logic controls things, but you can pretty much swap trannies around fine, as long as the gear ratio matches. That's the most important part!
March 10, 200422 yr Author ok - no laughing, but how do i figure out the gear ratios? and can anything be changed adjusted to make them compatible with the car? Thanks!
March 10, 200422 yr well.....depending on the year......you can figure it out....or by the owner's manual. right now....all I have to offer is this vin decoder. There is probably one similar for the transmissions... http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/VIN_decode.jpg I suppose you could swap stuff around in the differential, but that's a fair amount of work....you'd be better just finding a different transmission.
