August 12, 201114 yr hello, i just a weber carb (36dca-rally) and i want to install it on my ea71 engine. i need yout help with gettin it fit with an adaptor plate. from where can i get one? (im from israel) is it posible to make an adaptor plate? anyone have sketch of that adaptor plate? thanks alot...
August 13, 201114 yr Check out the offroad forum, theres a sticky thread just for weber carbs and putting them on Subarus. You can make your own adapter, I used two peices of aluminum bar, or you can buy one from Redline Weber. The Redline adapters are prone to leaks and their customer service is horrible, so if you can, make your own.
