August 14, 201114 yr should i re toque on Subaru BECK/ARNLE- head gasket on EA82? how much ft lb on nine bolts. step one- 25 ft lb step two- 43 ft lb step three- 47 ft lb after to step four to nine is 56 ft lb?
August 14, 201114 yr Just saw another one of your posts. Are you using FelPro or B/A Head Gaskets? FelPro are not supposed to need a retorque and are the recommended gasket on the board here.
August 14, 201114 yr Author Just saw another one of your posts. Are you using FelPro or B/A Head Gaskets? FelPro are not supposed to need a retorque and are the recommended gasket on the board here. yea, i was replace new felpro but somehow have damage head gasket and milky coolant becuz of i was re-toque also over-tight after three steps.. so, B/A head-gasket should be re toque or not? i'm ask how much ft lb for head cycle bolts? i've been spend $ for three times, new head cycle also 8 times rebuilding on ea82. because of there was badly leaky (head cycle block, master cam-lobe leaky and oil pan leaky) im totally Polish.
