December 2, 201114 yr guys, i need some help since i am confused of the issue. My moms car has 63.000km only, 2001 , first owner, Impreza wagon awd Ej18 non Turbo. -Power light flashes, so we had it scanned, came out code 75 (line pressure solenoid either the sensor or circuit issue etc) -Easily i found online the sensor part # and ordered it. -Changed it, flushed tranny fluid with new one, chek all sensors inside oilpan,changed line press solenoid, same issue, light flashes still ! -A subaru mechanic was contacted, he checked the car for me, and he found a circuit/broken wire/dirty plug under car around tranny , he fixed it, light WAS out, for 1 day. Now i have to bring car back to him, which will happen either tommorow or so. My Question : What would be the issue or sugestion to chek now. Rishi
December 2, 201114 yr It sounds like the issue may be in the wiring itself, and may be related to worn/scraped insulation on the wire for that particular sensor. This is causing the overall circuit resistance to be outside of normal parameters and throw a code. So I'd try and focus on the wiring itself, and narrow down where the problem is. Try moving it around and see if that changes the resistance when using a multi-meter.
