newgen85brat Posted January 13, 2012 Share Posted January 13, 2012 Suspension question. I was just under my 85 brat working on the thing when I looked up and noticed on the front center part of the axle there is a bolt sticking straight up with nothing attached to it. I looks as if it is supposed to have something on it. What is it attached to or supposed to? I looked on Subaru Parts Warehouse and see it looks as if a shock attached to it on the back side but the front side there is simply a description of "arm brat". I will look in my manual but it is pretty vague. It looks as if this is a counter balance or strut or something that would counter the trailing arms. There is no bracket on the bottom of the bed to attach anything to but there are "holes" torn in the bed from someone pulling the seat hardware (I think). I bought it as a project and have just now got to this part. The guy I bought it from just wanted to mud it and I am finding mud and "half assedness" everywhere. No Brats in the area to compare it to. Thanks for your help as always. Quote Link to comment Share on other sites More sharing options...
newgen85brat Posted January 13, 2012 Author Share Posted January 13, 2012 Just a follow up, this is the "axle" as Subaru Parts Warehouse calls it. It is the one that the trailing arms attach to. Rear suspension is where I found the diagram. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 13, 2012 Share Posted January 13, 2012 That isnt the axle, thats the rear subframe, it has the torsion bars for the rear trailing arms inside. The torsion bars are connected in the middle to a deal that has that bolt in it, and that bolt is actually to adjust the rear ride height. If you screw it in all the way, you can gain up to 2" over stock of ride height. -Bill Quote Link to comment Share on other sites More sharing options...
newgen85brat Posted January 13, 2012 Author Share Posted January 13, 2012 So it does not connect to the frame in any way? It looks like something is missing but I will try to squeeze up higher and see if it looks intact. Thanks. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 13, 2012 Share Posted January 13, 2012 Nope, it is just an adjuster bolt. Nothing else should be attatched to it. -Bill Quote Link to comment Share on other sites More sharing options...
newgen85brat Posted January 14, 2012 Author Share Posted January 14, 2012 Thank you, I see how it works now. Thanks for your help as always. Quote Link to comment Share on other sites More sharing options...
