March 10, 201214 yr I have no turn signals but the flasher's work so the bulbs r good I think is there a separte flasher for the turn signals,if so where is it located?
March 10, 201214 yr Author None there that I can see and not 1 liste on the cover but thx for the idea
March 11, 201214 yr Author I have found under the panel under the steering wheel column to blk relays1 says ILLUMI CON UNIT it has 6 prongs[ =--= except the 4 prong r in line w/each other] the other relay says TIMER(15)ASSY I SAW ON ANOTHER SITE THAT The flasher should have 3 prongs HELP
