April 4, 201214 yr Hi all, is interchange correct for fenders and hood? All the same (Brighton, L, LS, LX, Outback) coupe, sedan and wagon? Thanks for the info!
April 4, 201214 yr According to cars101.com the scoop on the OB Sport model didn't start until 97, but the scoop hood is the same shape other than the scoop, still fits the same. Pretty sure the body didn't change until 02. So anything from 93 - 01 should fit. That should help expand your possibilities.
April 5, 201214 yr Ive always used the headlights as the key. If the headlights match in shape the entire front end will swap with no mods. And with a little work, you can do almost anything like said 93-01.
April 5, 201214 yr Author Thanks Shawn, what did you do with the early Impreza being parted out last year? Still have it?
