nothing when turning key
Hello
I was tracing the br/yel wire from evap can. unplugged plug on front pass side kick panel,ohmed wire to plug at evap coil,they were good, unplugged 3 plugs from ecu unit at pass. side floor br/y was in bottom one,ohmed from ecu to prev mentioned plug, it was good plugged back together at pass kick panel an ohmed from ecu plug to back of car at conn. it was good,NOW i had previosly un plugged brown conn. under intake man. cause i thought wire was there,but after plugging wires back together insidecar and at evap can, i cleared cel code and tried to start car , nothing happened, daaa forgot to plug brown plug together under manifold, plugged together tried to start car still nothing no click no nothing , soooo i thought maybe alarm locked out starter,everything else works in car new battery when turning key it does not phase voltage cause nothing happens, checked fuses,and main link in fuse box under hood,pulled all plugs from ecu and unbolted to look at terminals all looked good but 2 looked bentup fixed them still nothing, how do i get car to turn over WHAT DID I DOOOO
I solved my problem,the connector behind the brown one under the manifold, goes to the trans here it does not have a lock and when i pulled apart the br one it must have started to come apart plugged back together it started up,i tried wiggling shifter rocking car to make sure it was in park who would have thought daaaa
